Anyone jack up the front of their Gen III with a jack under the center of the subframe?
Don't- unless my car was a bastard child...
I've always done that to all of my cars, because it's faster, even though I KNOW they have other lifting points- always been without incedent- until last night. I was changing front brakes, and it was going to be the fastest brake job ever- lowered the car exactly 38 minutes after I pulled it into the garage. Backed out, had a dust shield scraping, so I pulled back in and thought nothing of the puddle on the ground under the passenger front. I slide the jack under the passenger side, and see dripping coolant.
WTF?
So I jack it up, and sure enough, there's a leak.
My car (I guess it's factory routing) has a coolant line, running between the subframe and the inner fender. When you lift the subframe, the coolant line gets sandwiched between the subframe and the sharp seam of a fender panel, in effect- a giant pair of shears. Crushed the metal hose joiner placed right there, and cut the hose the second time I did it. So that blew my NASCAR pit stop, and caused me to need to run to AutoZone for a new 3/4" connector and 2 gallons of new coolant.
On the bright side, I learned something, and now I don't have to flush my coolant next weekend, like I was planning on.
And I even got to see James at work because I needed a bag of oil dry... :laugh_ti:
As always- saving 5 minutes cost me an hour. But my brakes are awesome!
WTF?
