Left rear tire leans in on a 92
munkee
Too busy...
Missoula, MT
Hey all, I am getting very close to getting the 92 licensed and on the road. It runs well now, although it does need rod bearings which are planned. I noticed the other day though when I pulled in the driveway behind it that the the left rear tire tips way in and sits further up in the wheel well than the right side does, like this /___| . The top of the tire is actually just above the rim of the well, while the right side has about 2 inches of clearance. I took a quick glance under it and didn't notice anything bent or out of the ordinary, but it was a quick glance. What would cause this and what should I be looking at? Also, is there a writeup with pictures for replacing the struts and springs? That's pretty much the only thing I have never done on these cars and all of mine need it. Thanks, Chris.
ohfosho
ontario SHOwner
ontario, canada
check it out again on a different spot on the road... see if it is still sitting funny. rear springs are famous on most fords for breaking. you need to take it in for a safety? they will probably check it out and tell you what is wrong.
ribeye2065
