Done with DRL. Works like a champ. I eventually even figured out the T tap. I used the Courtesy light adapter so for the turn signal I had to splice THREE (3) wires into one The original power wire, DRL Ignition wire and Courtesy light wire. Sadly the T Tap didn't work for that one and I had to use a regular bullet splice connector. The T tap worked on the passengers side amazingly.
Install tips. Remove the lower forward splash shield I know its a few bolts but worth it instead of trying to peel back and possibly break.
Drivers Side: I recommend removing at least the drivers side tire. It will give you more room to work with the fender splash shield. I wound up removing the inner fender shield for a possible addition of a side turn signal but will have to wait for another time.
Remove the Air Filter Box it is a easy removal and will provide much more space. Two bolts two clamps and one connector. Set lower housing aside....also a good time to clean the inside of the box. I loosened the clamp from the Upper housing to the Throttle body and set both aside...Don't forget to re connect MAF sensor before starting engine for Ops check otherwise you will probably get the M.I,L. (Check Engine Light)
I did all the hook up and did the battery connections LAST.
I ran the passenger side turn signal wire behind and under the strut tower cross brace. Ziptied and wire loomed. The passengers side strut tower has one connector along the forward edge, I ran the wire and wire loom under that than almost a straight shot to the turn signal wire.
NOTE: Follow the wiring diagram carefully. Perfect Example. Drivers side the Turn signal supply wire Blue Green I believe is the middle wire.
Passengers side Turn Signal OEM connector Yellow/Purple I believe is one of the outer wires of the three. I guess using the same outer middle inner wire to perform same function on each side would be too easy. Rant complete and also wipe the wires with cleaner makes them easier to see. Colors are close and just close enough to be confusing. For Reference take the DRL Kit....Fairly simple Red, White, Orange, Blue black.
There is a step to add the fuse box adapter for the kit. The fuse adapter is from the controller. If Using the Courtesy Light Adapter then use the Courtesy light fuse adapter. Same Fuse location just different function . When finished the Fuse adapter from the controller will be extra either cut off or tape out of the way for future use.
