myotis1134
Sorry for the delay... Got the LEDs installed some time ago, but poking around revealed other problems I had to deal with. Better late than never though, here's what went down.
First, here's some before and after pics.
Pre - Dim: (sorry no before - bright)
Post - Bright: Post - Dim: Post - Front:
As you can see (sort of), there's a decent difference in light-output. The particular LEDs I installed are supposed to be in between HID and halogen lights, lumen-output-wise.
... Specifics. According to the site (VLEDS), these bulbs crank out 2500 lumen on low beams, and 4500 on high. I'm not certain how that compares to the Sylvanias, but there is a definite difference.
Here's a link to the LEDs I got (9007 LMZ Platinum Ultra Output High/Low Headlights)
I got four boxes in the mail, two were the bulbs, and two were the controllers. The controllers also came with 9007 harness adapters, so no wiring modifications were necessary.
Bulb: Controller: Adapter: Assembled:
I took some measurements to see how close the controller needed to be to the bulbs, and it came out to approximately 10 inches of wire.
Schematic:
- Unable to insert more (necessary) pictures, so I'll continue this in a following post.
Schematic:
