Leaky Intake
kubos
Czech Republic
I found a leak on my 2010 sho on the intake hose or the map sensor causing oil seeping onto the motor so im asking should i be worried (bcs of the amount of oil ) and ive got a underboost code ofc. The motor runs fine no blue smoke or oily smell
( sorry for the not so good english, not my first language)
SHO-moco
ct
that sensor is the boost sensor, the map sensor is on the top of the intake. Under boost code can be from a number of different things. That air intake hose being cracked or that noise maker having a leak can both cause that code. Oil coming through that intake hose is common especially without a catch can installed. If you don't have a catch can the CAC can fill-up with some oil causing boost issues and oil in that hose. But you are saying you are getting no oil smell or smoke so not sure thats whats going on.
