Leaking P.S Hose
89SHONOFF
Columbus,Ohio
Ok today i took a look at it and i wasnt going to get under the car because it was poring rain out but i did figure out which hose is leaking on to the cat. it is the one comming off the p.s cooler if your facing the front of the car its on the left.Where does it go i see it go behind the engine but thats all i could see i can tell it was leaking bad the little plastic cover on it on the inside was full of fluid how nard is this going to be,can i pick up the exacxt hose for it or should i just go buy a certain length?Thanks
1989 SHO Lt.Titanium
K&N Filter
Msw Wheels
Hopefully More Soon!
1968 Buick Skylark W/455 Stage 1
70 Ford Torinow/302 and 60k miles.
pritch55
Minneapolis, MN
That would be you Cooler To Reservoir hose. You will need to pick up a 3/8" hose in around 78" of length. This by far is the easiest of the three to change. I ended up changing all three to avoid any leaks in the future. Make sure that you leave yourself plenty off slack in the hose, Otherwise it will rest on the exhaust manifold. I was able to pull the old hose and push the new one through the hose insulation from the Reservoir end.
-Brandon
[This message has been edited by pritch55 (edited 11-28-2001).]
crystizel
