Leaking fuel
ghostrider
Mt Juliet, TN
Was going to dyno the beast over the weekend, but it developed a slight issue. It started leaking fuel. The drip is coming from the driver side front corner of the tank. This leak reared its head right after a fill up. After 150 miles, it is still leaking. Any idea on where it might leaking from? I don't believe there are any hoses on that side of the tank that could be leaking. With the cost of fuel nowadays this needs to be fixed ASAP.
Sho-Driver
Peter Pan
The Garage.
If you cannot physically find a leak, you may want to look at the fuel pump mounting plate. I have seen the o-ring swell and not seal up properly, thus causing to leak.
