The lurch is somewhat a desired effect as it is designed to put you in the next gear with 10-15PSI instantly (as in, it never drops lower than what that engine load would produce). There's no way your feet will match what bouncing it off a set shift rev limiter will do for keeping the turbo spooled, unless you just want to bounce it off the 7-8,000 RPM limiter.
If you ever make it out here, you can take my STi down our local drag strip.
