Well it turns out I do need help with this installation. It is the rear cam, the one with the cam sensor on it. The cam sensor is removed as is the shutter wheel and the bracket that the sensor was secured to. However there is still the a "shroud" in the way. It has two 10 mm bolts on the top half - which I guess secure the bottom half to it. I pressed the kwik-sleeve on as far as it would go already, but I cannot access the the metal lip of the sleeve to tear it off as the "shroud" is in the way. Is all I have to do is remove the two 10mm bolts to remove the part that is in the way? Or do I need to remove the intake and valve covers - which I will be doing at some point anyway. Also - now that the sleeve is on I wanted to see if the seal would fit over the sleeve, but try after try, I can't get it started. It is a Timken - the one which has an outer face that is metal with the rubber seal on the backside of the inner face the small spring in the rubber seal. Just thought I'd describe it so you have as much information as possible. I was thinking of ordering one of the full rubber ones as it might have more give to compensate for the sleeve being on the cam now. Any help would be appreciated.
