Konis oil leaking
FastAndFurious
Washington
One of my konis is leaking oil. A few weeks ago, I saw oil around the adjusting ****, so I cleaned it off. I check it frequently, and there is oil all the time. It's not much but it is definitely leaking. I also found out the adjusting **** is moving up and down (I can grab it with two fingers and pull it up, and it moves up. It does require a little bit of force). Has anyone had the same experience? I've searched, but I couldn't find the answer. Should I be worried about it?
