knocking?
blk\blk90
TX
Hey guys, I got a problem(don't we all). My car started making some bad noises the other day.
1: When I start it up it makes a bad knocking sound for a couple seconds then goes away, then,
2: While idling it makes a faint tapping/knocking sound and last,
3: While driving around, once I hit about 3K the motor starts to kindof knock I guess. No real way to describe it. But it does it in every gear all the way up to redline.
The car has been sitting a while; driven about every 2 weeks or so. It was fine then one day it just started making noises. THe car has about 162,000 miles on it and has'nt had a 60K yet. Could that be it or maybe something down lower? :huh: It doesn't sound like valve tapping. I don't even want to start it now.
Jrodm12
Wa State
Around where is the knocking coming from the top end of the motor or the bottom in the front of it. Could it be bad rod bearings? See if you can find out around where the knocking is coming from. Have you tried seeing if you have any codes?
blk\blk90
TX
I had one code awhile back, forgot the # but it was something about the SPOUT signal :shrug: . I don't really have any means to tell where it's coming from. I'm afraid it might be the rod bearings. I hope not; I'll replace those when I have $.
