quadmasta
That would work, but it's electrical, not mechanical. That kinda current would drain your battery I think.3.8Lwagon:
what about using a line lock but installed in the rear. or two for all 4 tires.
This would still **** your battery. Probably faster too. When the brake pedal is down, the brakelights are on.3.8Lwagon:
hummm i think they also make a mechinacal version too. were you press teh break and then twist a ****.....
hehe you could always set you seat to work as a park break. slide it back engages it. sliding forward disengages hehehe all you need is to hook the cable up hehethe only problem now is the distance between you and the airbags.
I know what you mean I had an external MTX crossover with an additional Alpine 14-band digital EQ30footSHO:
Of course, not everybody has built-in crossovers in their decks.![]()
Dave
