Keypad replacement
Sammage
Wichita, KS
Tried searching for info on this...didn't find much. So this morning I walk to my SHO and the 9/0 rubber button was torn off, probably by some idiot :mad: I was wanting to know if the individual buttons can be replaced, or if the whole rubber piece(all buttons) needs to be replaced. Also, where would I find them? Junkyard, Alfitz or SHO-parts.com? Thanx in advance guys.
texas hot rodder
dfw texas
You can find them on e-bay for under $10.
My question is how do I get the one out of my door. I cannot figure out how without pulling the glass, I just have not spent much time to do it. The one on my parts door looks brand new and want it on my car,
how does it come off the door, do not feel any nuts,clips, tight space.
Sammage
Wichita, KS
I have yet to try removing it, the cover was missing this morning...I'm still trying to figure out who would do it...it doesn't really **** me off as one button is sticking anyways. I'm just thinking WTF?!? :confused:
Thanx for the ebay tip
Sam
Sammage
Wichita, KS
Ordered one from Al Fitz for $25...still no clue on installation...Chilton's was no help...nothing on SHOtimes...guess I'll try dismantling my door when the keypad comes in... shrug
Sammage
Wichita, KS
From what he told me, it's really just a matter of removing the door panel with the window up and sliding out a metal retaining clip. I'll post more when I replace it this weekend.
Later, Sam
FAST4DR
You just replace the keypad. The codes and the function of the keypad is a black box on the drivers side of the trunk against the back seat. The keypad is held on with a push on clip. The clip gets pushed on sideways to the keypad. Like a U around I think each side of the keypad. IIRC I thought I had to take the glass out but I am not sure. For some reason I remember thinking that the glass was in the way of the keypad up or down. If you need to remove the glass it is real easy. You have to drill the rivets out. First push the center of the rivet out. It is the pin that squished the rivet when it was put in. Once you push that center pin out then take a 1/2" drill bit and chew the shit out of the rivet until it pops apart. The window lifts out by tilting the front part down out of the track and then lifting the whole thing up. Just put it back in the same way and use bolts to bolt it to the lift. I recommend the nuts that have the washer built in so they don't work loose.
BlackOnBlackATX
Dutchess County, NY
anyone know about replacing the lights under the keys? ive been thinking about changing mine out, wondered if anyone here has had an experience with it.
313tiger
