Keyless entry pad
Alan
Arlington, Texas
I have a 94 sho that did not come with the keyless entry pad on the drivers door. I am wondering if it was possible/how hard it would be to install one from another car? Any suggestions or comments welcome.
thanks
alan
munkee
Too busy...
Missoula, MT
probably not too hard. I am pretty sure all you would need are the components from the trunk and the wiring up to the pad on the door. Then cut a hole in the door for the pad to match the hole in the donor car.
projectSHO89
SHOless In St L
Better check for the wiring harness first. Without it your job becomes unreasonably difficult.
Go to a junkyard, find a car that has it, identify the harnesses and plugs, then go back and compare with your car.
Steve
FordLover
Houston, Tx
projectSHO89:
Steve
The non keyless entry cars don't have the wiring. I looked into doing this on mine, and it proved to be a very involved job.
-Martin
