key broke off in ignition
shopower1113
colorado
I just got home and I went to turn my car off. The key broke off in my ignition. Any ideas on how I can get it out. Am I going to need to take the whole thing apart? It is a 91 if that makes any difference.
HoustinoJillian
name's JUSTIN
usa
this happened t omy mom once, my dad was able to get it out with a shaved down screwdriver, and a lot of finesse :read "cursing". best bet, call AAA/locksmith, you dont want to screw the ignition cylinder up
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
if the ignition still can turn with broken key turn it to the run position,through access hole on bottom of the colum,use a pick or small screwdriver to release lock in pin and pull out the tumbler assy.Just bought the tumbler two months ago for $18 at autozone.
norurb
SHO wannabe
Keizer, OR
Did it work? Were you able to get that out? I just had this happen to me today. dang! and I had just fixed the reason why my #18 fuse was blowing.
SHOslyter485
Fort Collins, CO
This happened to me.. I was able to work it out with a pair of tweezers and a screwdriver. As Jillian said, it takes time and finess..
Justin101
It's A SHO Thing
Rocky Hill, Connecticut
happened to me a few months ago, i just took apart the ignition cylinder and the key just fell right out, put the ignitions cylinder back together and it was as ez as pie! if u do take out the ignition cylinder just be carefull u dont loose any parts, but IMO very ez to get the key out! :thumb:
dmbturbo69
waukegan il
Best bet is locksmith if you cant get the key out, if you change the ignition then you are up to 3 keys for the car, locksmith can rekey the ignition. They can just extract the key also. Cheaper if you take it to them.
Or get a new AAA Plus membership, they will cover $100 for locksmith or tow up to 100miles
norurb
SHO wannabe
Keizer, OR
Yea, I tried calling the local Ford dealer, the key code is no longer available on their systems. dam!
Redline
Fire It Up
Sandpoint
I have had this happen several times. For some reasong my ignition is stiff and takes a bit of pressure when going to the "start" position. I have always been able to pry it out with a paperclip and tweezers or somethign similar. I also always keep a couple extra keys on hand for when the next one breaks...
dmbturbo69
waukegan il
Why do you need a code for? Ford only has codes back to 1997. I work for a locksmith and I could decode it by looking at the peices of your key and make another.
A local lock shop should be able to do that for you.
