Keep breaking a motor mount bolt
SuperHO
Mental Patient
St. Joe, MI
For some reason, I keep breaking the top bolt on my motor mount. It won't stay loose, then it finally breaks in half and falls out. When I had the 3.2 swapped in, richard welded a nut back onto the mount, but it's been broke off already.
So....why do I keep breaking my shit, and how do I prevent it?
93rev2sev
Hockeytown
All or nothing is what I learned about reinforced mounts...meaning...you gotta reinforce all 3 or your engine will twist in the engine bay because the energy from the shift wants to be redistributed to the stock mounts since they have some give. That twisting is a problem for 10mm steel bolts.
Start by reinforcing the rear. Then tighten the shit out of the front bolts and install stop nuts and tighten the shit outa them.
You may need to remove the y-pipe to really get at the top nut with your 15mm(or whatever)
SuperHO
Mental Patient
St. Joe, MI
actually, the top nut's now a 14mm with a valve cover bolt washer to keep it from pulling through when I torqued the shit out if it last time. IIRC, when we had the engine out, I think I noticed the rear mount had seperated. Guess it's time to go buy some bolts, some bushings and a few drill bits, huh?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Lol... I had that issue forever trying to put a bolt / nut thru there. Grade 8's were too brittle, and grade 5's never got tight enough. Welding a nut on the back is all I can think of.. maybe step up to a larger bolt?
yzstud
< my kawi
Minnesnowta
for real?
I put 4 bolts through both my motor mounts
When i searched awhile back ago, it said it wasn't a good idea to reinforce the tranny mount if the motor mounts were already reinforced
so should i do the tranny mount too?
SuperHO
Mental Patient
St. Joe, MI
So I tore the rear motor mount out last night......
Motormount3
that don't look too good. Sooooooooooooooooooooooo, let the drilling commence!!
Motormount2
You know you like my clamps.....
That's one of the best things about being a professional cook...the indifference to burns.
and the end result?
Motormount1
Motormount
I know...I didn't put the bushings in...but then, the rear motor mount mostly compresses anyway, so I'm not too concerned with snapping the bolts off. I'll get the front taken care of eventually, but even just doing that made a world of difference.
SuperHO
Mental Patient
St. Joe, MI
Paul....where would I put chain? Wrap it around the manifold or something?
I have mine wrapped around the exhaust manifold. Little easier on the V8 as it there is a hole in the subframe directly below the center point. But in the V6 it should be as close to the motor mount as possible I would guess.
SuperHO
Mental Patient
St. Joe, MI
****, half the stuff I do isn't safe. For example, I work in a kitchen....in my kitchen, you're supposed to use kevlar mesh gloves when you cut anything. It's definitately something I should start doing, cuz I bring my own knives and keep them quite literally razor sharp...but there's just something about wearing gloves while I cut...almost like wearing a ****** when I make a few fist babies...just not the right feel.
SuperHO
Mental Patient
St. Joe, MI
wow...i believe this puts me at 4 or 5 sayings that have made it into sig quotes....that's gotta be some kind of record, don't it?q
Phoenix
SHOHOLIC
QC , Canada
Good job with the reinforcement :thumb:
Who cares if its not safe when you only put yourself in the danger zone. If the worse happens , you will be the only one to blame. I got my share of crazy unsafe stuff done in the past.
38SHO
#1 Oil Abuser
North Palm Beach
I had one of you talking about someone blowing diff pins with launches and hard 1-2 shifts..... that and the post after yours damn near had me in tears when I read it
