K&N 0940 Conical Installed
OzzmanNT
Dinwiddie, VA
Following the instructions as per v8sho.com I installed the K&N 0940. I would actually recommend that you try the conical on the V8 SHO it definatly breathes better and it much much louder when the secondaries kick in. I'm going to do some custom heat shielding later but for the winter use this is fine. I belive the SHO shop intake is a little overpriced so I'm going to make my own. Anyone else on here running the 0940 setup?
1998 Burgandy SHO (Tan/Mocha leather)
K&N 0940 conical (What air box?)
Mobil 1 5W-30 Synthetic Oil
Cool Blue headlights (much brighter than stock and look much better)
OBD-II diagnostic Module (this thing is schweet)
Installing ride control switch soon
Upcoming Mods:
-Borla Exhaust (working with a local muffler shop on this)
-Paint brake capilers (or polish them)
-Colgan Bra
-SHO lettering on the doors
-Upgrade intake system
-and probally a few more as I think of them.
OzzmanNT( mailto:eek:[email protected][email protected]</A> AIM: OzzmanSHO)
CMurderSHO
pittsburgh,pa usa
That was my first mod. For 45 bucks vs 200 for the ss you can't beat it. I also need to make a heat shield but just never planned out what to use to make it yet.
96 silver frost
18" asa js5 wheels
245/40/18 kumho esctas
bullet turbos 3 1/2" tips
open K&N filter
powerslot slotted rotors
asp underdrives
triple guauge pod oil,volt,water
http://cmurdersho.tripod.com
OzzmanNT
Dinwiddie, VA
If I come up with a good design I'll let you know. Right now I'm thinking heatshield on the engine side and around the thing and plexiglass on the top, just a beginning idea
Upcoming Mods:
-Colgan Bra
P
PrplSHO
Guest
I just did mine too, LOVE that intake roar now.
I was thinking about heat shielding, since I live down south, I'll need it sooner than you I gather, Also, I started off with the air box and Porterized Intake, so now I just have that big tube running right up to that filter and out into the fenderwell, I'm wondering if I should fashion some sort of tube out towards the front of the car for more cool air.
1996 Taurus SHO
39K mi
Rose Mist
Thrush Turbo mufflers, No Res.
K&N Cone
Blacked Out signals
Roush Springs on the way!!
SHOntell
**** Rapids, MN US
I am have been running the cone for the last year. It was my first mod. It is a great sound. I also did the porterized this summer and actually just put the pannel filter in 2 days ago. I don't like it as much as the cone. I know some people have extended the cone into the fender is that what you are refering to lol? Which do you prefer? I plan on trying to extend the cone into the fender wall area once I find the proper sized tube. If you guys design a heat shield, let me know.
P
PrplSHO
Guest
No... I have heard alot about that being done, but I was thinking of just extending the tube a bit rather than have it end just outside the engine compartment.
5280192.ptp
1996 Taurus SHO
39K mi
Rose Mist
K&N Cone
Blacked Out signals
OzzmanNT
Dinwiddie, VA
I think the conical K&N sounds awesome....I haven't heard anyone's stuffed behind any heatshielding or in a custom "air box." I wonder if it would have the same sound...oh well I'll have to see.
Upcoming Mods:
-Colgan Bra
mholhut
MA
You're all very welcome for the inginuity I put behind making that mod and posting it on v8sho.com
FWIW, I made a custom heat shield out of aluminum flashing that worked pretty well. I even lined the top edge with some of that circular foam insulation. Just use some cardboard as a template so you can modify and trim it the way you want. Then transfer the cardboard to the metal flashing and cut it out with scissors. (flashing cuts fairly easy.) Dress the top with some of that foam inusllation and install. I fastened mine to the strut tower one one side and tucked it between the CCRM and the battery on the other.
I eventually had to get rid of the thing to make room for the Zex nitrous module which had to be mounted on the strut tower. Fair trade off I suppose
Cheers!
Mike Holhut
'96 Phantom Menace
SHOntell
**** Rapids, MN US
Mike, I owe ya thanks!! You gave me all the input I needed last spring. It is awesome to see the type of SHO enthusiasm there is out there and that everyone is in it together. Thanks Mike and all of you out there!!
1997 Ebony Satin
K&N cone filter
Bullet mufflers
Cincy SHO Bra
OzzmanNT
Dinwiddie, VA
Great job on the documentation. It was right on the money. Great job with your car too.
Upcoming Mods:
-Colgan Bra
