Just reset battery and...
SHOTerror
Orange County, CA
Just reset battery on my '93 left in unplugged for about a half hour like im supposed too and now the A/C blows full hot when I push Max A/C or automatic, no matter what I do it is hot air, and im not talking vent hot im talking like the heater is on hot. The A/C was working great before I reset, how can I fix this?
Mr Anonymous
Tire Wall
First, why did you disconnect the batty? Resetting the PCM can be done without touching the batty.
Second, was the A/C working fine before this?
Check the connector at the A/C clutch. The battery cables run right by there and it's possible when you disconnected the batty that you dislodged the connector.
SHOTerror
Orange County, CA
I did the 30 minute hard reset for the computer(pull negitive battery cable off the battery for 30 minutes, put back on). I read on SHOTimes that if you have an undersized battery that it can screw with the head a/c unit.. I have a undersized battery because it is smaller than the bettery holder itself, think this may be it? I'm going to see whats going on, i.e. check for clutch engagement etc. Man this sucks, first my '90 doesn't have A/C now my '93! God cursed SHOs!
SHONJ622
New Jersey
try running the self diagnosis test off ur electronic climate control if you have it. Reset the climate control settings...
As long as the battery is capable of supplying potential to the loads and maintain a voltage above 12.0V, the physical size will not make one darn bit of difference. The greatest drain on the battery is during starting. If it can spin the starter fast enough to fire the engine the battery should be sufficient. It may not last as long as a higher capacity battery, but it shouldn't affect the electrical loads.
thatSHOguy101
