Joe_sho build thread
Devin
3.Slow
Pacific Northwest
I guess that depends. Is there a minimum threshold you need?
Engine looks nice. Looks like someone overfilled the plug well with oil though. No crosshatching on the plug wires doesn't help!
Joe_SHO
ND
That was me! I pulled the wire to see if I had to do valve cover gaskets. The verdict is apparent haha. This will be a slow build over the winter. 3.2 engine going into my 1993.
Joe_SHO
ND
How do these look? Do the cams, chain, and tensioner look ok? These are pictures of the donor engine.
Looks ok in a pic. I can't tell how much material is left on the tensioner/chain mating surface. Also check cam lobes for pitting where the lobe contacts the valve shims while it's open. It's a little dirty but if the mating surfaces are good you should be fine. I would drop the oil pan and change the rod bearings.
Joe_SHO
ND
Thank you for your input. I haven't pulled the 3.0 valve valve covers. The 3.0 is prettier in every way so far.
which head are you going to use with the 3.2 block? In either case if the entire engine is out, easy to find time to do the valve gaps and replace shims.
Joe_SHO
ND
I bought a borescope camera, and I plan to check out the cylinders with it tomorrow.
I really hope it turns out to be minor problems so i don't have to 3.2 swap it immediately.
Joe_SHO
ND
Have you ever seen valve shims out of spec? Seems like an unnecessary worry.
Joe_SHO
ND
After seeing under the valve covers, I suspect the engine failed because the previous owner filled the crankcase with seafoam or gasoline instead of motor oil.
Here are some pictures of today's work. The unbelievably clean head and valve cover is the 3.0 that's in the car. The filthy head and valve cover are the 3.2 donor engine.
I can't believe how clean this engine is. The last picture is the tensioner on the clean engine. Very little wear on the pad, but the tensioner did not collapse when I pushed on it. I don't think I can bring myself to pull the clean engine and put in the dirty engine.
Clean head
Dirty headValve coversClean chain tensioner
Joe_SHO
ND
I haven't pulled many oil pans, but this looks filthy to me.
Would you use this engine or pay to have the existing one rebuilt?
Joe_SHO
ND
@StreetlightSHO I hope it takes less than a year, but I know myself better than that!
I tested compression the other day, and the rear middle cylinder (#5 I think?) held about 25 psi. The rest were about 140 if i remember right. I will soak it with oil and seafoam and test regularly, but that's where I sit.
2813josh
Stanley,wi
25psi on the donor engine? That doesn't sound good.
I am currently collecting parts to do basically the same swap. 95 3.2 into a 92. The 3.0 also looks much cleaner.
