J/Y guru's
Sho Amo
SmkTyresntDrugs
Olney, Md
anyone know if i can use gen1 slo calipers on my 91 sho?
Edit: nevermind, a new rear caliper is only $18 anyways
AREA 91
PA SHO SHOP
Area 91
The last set of rear caliper's I bought were $75 each, plus a core.
I believe any rear disc taurus/sable will work from 86-92 for the rear vented.
Sho Amo
SmkTyresntDrugs
Olney, Md
well why am i seeing it on that website for 18 then? i know im not shroomin
whiteguy3
Scott MacIntire
Silver Spring, MD
Ken check out that borla and see if there are an ZE's in there
Drew and I looked two days ago. Didn't see it there anymore.
And, the rear calipers from a SLO will work. The rear one's on Gen 2's and Gen 1's were the same from SLO to SHO!
Cocoa,Florida
gen 1's had vented rear disks and gen 2's did not thus IIRC the calipers are diffrent.
SHO92
Upper Freehold, NJ
He meant that all Gen 1 (SLO & SHO) were the same, and all Gen 2 (SLO & SHO) are the same. Just remember that the switch to solid rear disk happened in 93, so there is 1 year of Gen 2 that still had the vented rotors of the Gen 1.
Also, there may be a difference between Gen 1 calipers. The SLO came with phenolic pistons, where the SHO had steel. It's very possible that there are SLOs with steel pistons, but I'd double check when you take it off the car. The phenolics had problems with getting soft with heat.
Sho Amo
SmkTyresntDrugs
Olney, Md
turns out i didnt have to replace the caliper. put in some earl's stainless lines and no more brake light, dragging and pedal feel.
also greased the sliders.
ScottyDsntKno
NJ
Sorry to hijack but I have a question. Since the gen 1s and the 92s had vented rear rotors can we just switch to gen 1 or 1992 rear rotors when we need new brakes as an upgrade or are the calipers different too?
