is this the end????????????
iamsotired
tx
need major response. my 1993 atx seemes to have major issues. left work and
when i stopped car would shift to park but did not stop!!!!!!!!! then it would not
shift ouf 1st gear evevthought in drive. i had to stall it in gear to stop.
now the gear selector will move, but nothing happens, it will not start
in park. the fluid is full is the show over?????????????:omgsho:
ctwrench
Katy, TX
Is the linkage still connected? With the selector moving but nothing happening, check the cheap and easy stuff first. Where in TX are you?
jayro
Auburn, In
X2 don't know too much about atx's but it sounds like something came unhooked.
Racer X
SHO Pilot, Retired
Connecticut
Sounds like you have a linkage issue. Look on top of the transmission (underneath the throttle body) for the linkage. Have someone inside the car shift the gears, and check to make sure the linkage is moving the shift lever on the transmission.
