Is this crank cancer
350TPI
columbus ms
This noise started after racing an integra and going to redline a few times.I normally baby this car.At first i hoped it was a timing belt tensioner but the belt is VERY tight.The noise is a lot "lighter"than it sounds in the video.Whats weird is the car hasnt lost any performance or drivability.Ok,so give it to me straight.No matter how i try i cannot get this small enough to put on here.Can i email this to someone to listen to it?
SASHO91
Zoom Zoom
San Antonio,TX
Here is what crank cancer looks like in the beginning stages....
Josh065
this was caught in time, and was repaired.
350TPI
columbus ms
I will get these out as soon as i get home from work.Thanks for being willing to listen:hail: :hail:
yamahaSHO
E85 whore
Arkansas
Josh065
Mine didn't even make it that far... It broke and the wore the crank.
If you think it may be crank cancer, do the work now and pull it apart to find out... Or, Just torque the crap out of the crank bolt.
350TPI
columbus ms
The video i made is big enough that it wont even upload on hotmail.I will make another one that is shorter today.I thought this thread was gone forever when the forum went down.Thanks for the replies.
Bizzy
How long in minutes is the video and how big is the file? I can PM you login info to one of my ftp accounts if you want.
Depending on how bad the cancer is, it can and does make noise as it progresses. My son's 95 had crank caner which we didn't know about at first. This is the video/audio from this past summer. Please excuse the tone in my voice at the beginning of this vid, I was a little more than annoyed at the time. :frown: His car's cancer has since been repaired and so far, so good so.
The audio/video in this link is flash, if you don't have flash you won't be able to view it.
http://www.shoforum.com/ohshit.htm
SHOBlu
Habitual Offndr
New Sharon, Maine
:laugh_ti: Dammit -turn It On!!-Bizzy Thats funny
Sounded pretty bad. Mine never sounded like that - It made no sound at all. The "cancer" went about its business very quietly. I'm glad I found it by the off chance while I was looking for an oil leak.
Good luck.
350TPI
columbus ms
Bizzy,i believe its no more than a minute long.I have actually listened to your sons car many times and mine sounds different.Mine actaully sounds like a loose pulley clanging around but i have checked them.I am to the point with this car that i pretty much have made up my mind to sell.
SHO-NUF93
Zombie
Jacksonville, FL
Just because your timing belt is tight, doesn't necessarily mean one of your timing pulleys(idler or tensioner...if the SHO has a timing idler) isn't going bad. Take the cover off and get a mechanic's stethoscope, and touch it to the non-rotating part of the pulley while it's running. You should be able to find it somewhat easily. Taking the belt off and spinning the pulleys by hand is the best way to find it, though.
350TPI
columbus ms
Really?I thought it would be loose if the car was off.I have been terrified to work on this car.I have owned 40+ cars and this is the only engine that intimidates the crap out of me.Between the tight space and afraid of making things worse/not being able to get it back together.
SuperHO
Mental Patient
St. Joe, MI
it's no different than any other engine out there, except for that freaky lookin intake manifold sitting on top. Yeah, it's a little tight, but otherwise not at all too bad.
290
Loser of Keys
Sterling Heights, MI
Proper torque on the crank bolt. Its caused when the bottom timing gear comes loose and rocks back and forth on the crank. Bad stuff
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
oooohhhh now bizzy's voice is all across the internet :biggrin:
and you dont sound that irritated...
