Eric VerValin
PiMPSKiLLET
Ok.. where it meets the hard line is pretty rusty, yay Indiana! So without trying to crack into that, I was going to bleed them. I ziptied the proportioning valve so it is up, closed or whatever you want to call it, so I assume it should be flowing through there. Now I have a one man bleeding deal, just a one way check valve sort of thing, and after a few pumps of the pedal nothing. So I grab my assistant, still nothing seems to be working. I left the screw open, with my little bleeder deal attached, and had her pump the pedal. The fluid is going somewhere, cause the level of fluid drops with the pedal, but when she lets off the pedal, its right back to where we started, magically floats back to the top. Am I just compressing the fluid in the lines? And do I have to leave it running? I seen a few posts where people have it running to do it, and seen a lot of posts about collapsed lines, but just curious what I should tear into next.
Kinda stinks tho.. I was all ready to go driving.
