heatin it up a little,but the real question IS WHY?it seems like you could save it some other way.i think that i t would be to loud and alot cooler in the winter.the most you will save is probably 4 pounds.
Nuh uh. If you take all the carpet and all that stupid tar crap and put it in a big ball, it will easily weigh 100 pounds. You would not
believe how much that crap weighs. I'm talking about the carpet, the sound-deadening insulation, and the black gooey stuff that holds it on in the entire car.
as far as that black gooey stuff goes, methods I've tried in the past with some measure of success are: Razor/Goo-gone; Razor/BBQ lighter, Goo-gone/BBQ Lighter/Lots o' paper towels (not recommended for those with sensitive olfactory nerves), or really any combination of the three. The BBQ lighter (I say BBQ cos it keeps your hands away from hot gooey stuff) softens it up remarkably (make sure you don't melt it, though), and the Goo-gone is good for what remains.
FWIW, though, if you want to lose some weight, ditch the stock seats. They weigh 60-70lbs (depending on the change stuck inside) a
piece.
After that, you'd want to ditch unneccesary electronics and wiring (it can get to weigh a bunch... cruise control, ABS[if you choose], radio, air bags[not recommended unless racing fo'real], etc). Windows would go as well, replaced with polycarbonate material. Don't forget the trunk carpet material, that stuff really throws the center of gravity out. You should also relocate the battery to the trunk to free up real estate in the front - and give better balance.
The rear seats will give you about 20-30 pounds. You can cut out the mounting brace for the amps and stuff; it's not structural and it'll give you a ski pass-through!
A/C is an obvious delete if you can live without it. The compressor, condenser, tubing, hoses, etc. all weigh a TON!
Any of this helping?
