My 93 ATX has been having trouble starting lately. It seemed that every time I'd try to start it, it had to turn over a little longer before it would finally "catch".
Luckily, the last time it ran was when I started it to back it into the garage.
I hooked a fuel pressure gague up to the shrader valve on the fuel rail, and turned the engine over. It showed that there was no fuel pressure.
I'm thinking that since it slowly failed to start over a period of time, and since I don't have any fuel pressure, that the fuel pump is bad. I've always thought that mechanical things, like fuel pumps, can fail little by little. (As in taking longer and longer to pump up and get fuel to the engine) Electrical things are either working or not. Well, except for that old T.V. I use to have that worked better if you smacked it on the side.
Before I drop the tank, is there anything else I might want to look at? I've checked the safety switch in the trunk, and the red button is still pushed so I'm assuming that is ok.
Thanks for any help,
Rob
Rob
