Interior LEDs
silver93sho
I've got a two part question- first, anyone know what the voltage to the window/door switch LED lights are? I'm wanting to swap them all out with blue. Also, where can i find LEDs for the instument cluster lights??(puttin in white face gauges)
93 mtx silver-super sleeper, in the works
01 mustang mtx triple black
:omgsho:
Danz13
ATX Sho Member
Rancho Cordova, California
When I did the door buttons I think I just dropped a new 3mm? led in there and it worked fine, I believe there are resistors already into the stock ones, if not, then trial and error
Storm-Chaser
Shit Louis
Do a search. Several years back, there was a forum member that re-did his entire interior, including all the door switches with blue LEDs. He included in his write-up, the LEDs he used and how he stepped-down the voltage.
the4biddendonut
Hurry up meow.
Elk River MN
It's 12 volts. Probably the easiest way to step down the voltage is with resistors. If you order the LEDs off ebay they come with free resistors. Just tell the seller what voltage you are hooking them up to and they will send the right ones.
silver93sho
well, i figured they where around 3-4v after getting stepped down from the 12v source....im getting my hands on a multimeter and checking it out. thanks all. and im going to start the long process of converting to blue interior.
Danz13
ATX Sho Member
You may need to sand down the led so the button will clear when pressed down, I have to redo mine because i think they broke
NoSlo
SHO Owner
Portland, OR
I think I'm the original blue LED modder.
LEDs do not require a specific voltage, they require a specific current. That's why the additional resistors are 'current-limiting' resistors. They have electrical properties quite different from a normal light bulb.
The door panels have a custom size of LED that I didn't easily find anywhere. You can take a 3mm mini-LED, and sand or clip off the ridge around the base so the LED will fit in the hole where the original LED was. Also note that LEDs are diodes, and power only goes through one way; if you wire them up backwards, they won't illuminate.
The door switches have resistors (about 300 ohms if I remember right) that are correct for the amber LEDs that are there. The blue LEDs will have a different current draw and need a different current-limiting resistor value. Since they are based on different technology than the old red/green/yellow LEDs they will glow much too bright and burn out themselves or burn out the old resistors. I think I replaced them with about 4k resistors to get them to glow with the right brightness. You really should have them very dim, so they don't distract when you are driving, just enough glow to show the button in the dark.
Ledswitch1
Ledswitch2
Ledswitch3
I got a bag of 100 LEDs on ebay from Taiwan for cheap. They were almost certainly 'rejects' because they were wildly different values, and I had to test them all to measure the current draw and evaluate how bright they were and bin them by brightness.
the4biddendonut
Hurry up meow.
Elk River MN
I stand corrected. I could have sworn I measured source voltage. Sorry if I created any confusion.
In the picture it looks like you used a 360 ohm or a 3.6k ohm resistor for the one side, if I'm reading the colors correctly. Sounds like it's the 3.6k ohm maybe???
hawkeye18
Sorta cares
Norfolk, VA
red blue brown = 260 ohms.
The other two are harder to read, but it looks like brown black red? Which would be 1Kohm. Two in serial means 2Kohms total. Total parallel resistance would be 230 ohms. On a good day.
nothingtoseehere
FWIW, I had Brad in NY do the switches in my Gen III. After seeing pics of everyone's blue switches, I decided it would be way to bright and distracting. I had red LEDs put in and it was perfect. Plan on the same for the 95
