Interesting (maybe?) story and question involving the cooling system
Liquid_force
Lawrence, KS
For my 3 y/o's birthday me, wife, 11 y/o daugher, and 3 y/o son along with a few other family members and friends went to a Royals game.
Over 100 mi round trip and it was one of the first hot days of the year so before leaving a popped the coolant cap to check the level and measure concentration (hoping to clear the "low coolant level" light). Looked good.
So - drove 50-60mi to the game which included 5-10 min. idling through the parking lot. Low 80's, A/C running all the way.
Idled out of the parking lot after the game, mid 80's, drove back home and did a half hour of city street driving - air on all the time.
Pulled in the driveway -- splash. The cooling system is puking.
Uhh, ok. I guess it blew a hose.
Naturally, I raise the hood and take a look. There's my coolant res cap sitting loosely so apparently some ***** forgot to put the cap back on, or at least didn't do it very well.
That's a pressurized over-flow isn't it?
How did it keep from blowing out over a 120 mi trip with a half hour of stop-and-go?
LJRuddy
Pop lock n drop
Poaceae fields
My bet is your tightened the cap but not enough to make it "click" like the oil fill cap does. It held pressure for a while but after the 1 heat cycle, it worked its way lose.
newshofan
chattanooga, TN
When I ran my rad cleaner through mine a few weeks ago my cap did the same thing.. I was in a parking lot 30 miles from home at midnight I actually heard mine pop off. Figured I didn't have it on good enough. When I flushed it the next day with fresh fluid and tightened it back up it would just keep twisting off I figured bad thread or something. I replaced it with a new one stant#10238.
So I guess its good to replace every so often just like a traditonal rad cap. Also my old one nor my new one clicks close and if the cap doesn't hold the proper 16psi the fluid doesn't make a complete round through the core and all causing your heat not to work just an interesting bit of info
If you cross thread the cap it will ruin the tank and not hold pressure.
newshofan
chattanooga, TN
Yes I was afraid that the tank thread was bad. But the lady I bought the car from had just replaced the tank with a new one from ford. But she must not have replaced the cap because I believe it was original. I took the cap apart its pretty much a spring type design mine was pretty nasty and seemed almost corroded.
newshofan
chattanooga, TN
Yes the res cap. I don't believe there is a rad cap on v8 sho. Not like the v6 that has both. And yes the tank has to hold 16psi or the heating and cooling system wont flow right
Brad kirk
