Intake Problems!!!
New to the SHO
PopGoesTheWeasel
portland
I took off my intake, took it apart and cleaned it. But now when I tried to bold it back on I cant get the rear bolds toward the firewall on. they wont line up. I have all the bolts on around the intake runners. Also the piece on the left side containing the DIS the bolds wont line up either.... Can you think of anything that I could be doing wrong?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
For the Crossover tube (part that the DIS is attatched to), simply loosed the hose clamps on the two large hose connections. This should allow enough wiggle room to bolt the crossover tube down.
The rear bolts? We all have that problem :bonk: . They are a PITA if you havnt had the intake off a dozen times or so :lol: . Just keep at it, dont break anything, and do not cross thread anything. Take your time and do it carefully.
New to the SHO
PopGoesTheWeasel
portland
Also I forgot to ask about the Throttle Body Wires. How does it bolt back on to the throttle body?
