intake manifold
bubba
ATX Connoisseur
Fort Wayne, Indiana
Is there anything else I need to do while I'm in there? IAB EGR nostrils are getting cleaned out should I do anything else?Or should I look for leaks everything looks good. Everything looks clogged up. I was not wanting to do this up it's not too bad getting in there I'm about half way there. and I want my knuck skin back.
whiteguy3
Scott MacIntire
Silver Spring, MD
1.) Check for leaks, clean all the nostrils right past the throttle body. There should be 4. 2 for the crankcase ventilation that runs through the pit of **** below the injector rails and 2 the for IAC.
2.) Also you could turn the intake manifold over and remove the two large hex bolts to clean part of the EGR. That area is when exhaust fumes run along the bottom of the intake to the EGR.
3.) Most importantly check all of the couplings. Those things can leak like crazy if cracked. I just made my own new couplings with 2" length pieces of heater hose cut by hand. Works like a charm.
4.) I recommend replacing all of the vacumm hoses too...If they are old and dried out.
As a temporary fix for the intake to head gaskets you can remove, clean and then spray black spray paint to them which helps with a better seal.
bubba
ATX Connoisseur
Fort Wayne, Indiana
thanks yes all of the hoses looks great. Eric VerValin are cleaning the whole intake. thank you every much
shobroooo
