Intake Manifold Question?
shofan33
Slick Silver
Edison, NJ
I recently disassembled my intake to clean it. And i saw that after you take off the butterflies there's tubes inside the tanks. I was wondering if I discard them will it perform better or sound better? Or if i pierce them will it make a supercharger whine after 4k? Please help. :shrug:
Ishodu
The are there to tune the length of the short runners, you may get a little bit of top end, (may) at the cost of a loss of low end TQ.
Rockledge
Pluggin' away
Connecticut
What Marcel said. You have to keep in mind that there is a certain theory behind a "tuned" intake.
http://auto.howstuffworks.com/question517.htm
I'd have to think that Yamaha knew what they were doing when they designed the SHO's upper intake. It certainly looks like they spent a lot of time on it (somebody recently posted links to some of the patents - interesting stuff). So IMO it's probably a better idea not to fiddle with the horns.
AREA 91
PA SHO SHOP
Area 91
I believe the general concensus here is to leave the "horns" in your intake, unless you have BBB's or EX runners.
nkb93
SLO 4 SHO
Charlottesville, VA
When I removed the intake horns, my butt dyno sensed a slight loss in torque right around 4k RPM (when the secondaries snap open), but the sweet intake sound that resulted was worth it, IMO.
somedude_001
Western NY
FYI the intake horns he is refering to are on the secondaries (short runners) so there will be 0 loss at low rpm's so the only effect is at 4K+
shofan33
Slick Silver
Edison, NJ
Well i bought my bbb's and was going to slap'em on without the "horns", that will make the personing im passing on the freeway very scared! :evilgrin:
