if youre careful the gaskets can be reused, but are not horribly expensive in case you make a boo-boo. but as far as i know they are pretty tough to destroy.
alot of people recommend the B-12 chemtool over the throttle body cleaner. i used the STP cleaner when i did mine, but this Berrymans B12 is supposed to be good stuff, so if you can find it i recommend it.
if you need to do the plugs you might as well do it if you have the manifold off, you gotta have it off anyway and it just makes life easier i suppose (although many people can do it with it on, but not me wink )
if youre going to have it off and clean the throttle body, make sure you decarbon the EGR ports (there is a procedure on shotimes.com) this way you wont have to do it down the line, although you may have already included this idea in your cleaning agenda.
i *highly* recommend since you live in NM to bypass your throttle body coolant line (there are a ton of posts on how to do this, no special tools needed, just a pair of pliars). this will keep your incoming air cooler, also you may as well bypass the PCV system to keep the intake clean after you put it back on. this only costs $4-$5 for a tiny fuel filter or more if you want a real catch can.
before you start though drain about a gallon of coolant out of the radiator and you wont spill anything when you take the throttle body off. and if you need to change your thermostat you may as well do that too since its easier to get your hands in there when the manifold is off.
take a wire brush and scrub the connections that the crossover tube bolts to since your DIS is grounded here. bad grounds cause alot of problems, this happened to me.
it may seem to take forever the first time to have it off, but when you do it again, it will go quickly. i can have mine off in 15 minutes. taking pictures with a digicam as you go is a good idea too if you dont think you can remember where all the hoses, connections go.
i know its long but i wish i knew then what i know now
<small>[ January 13, 2003, 05:10 PM: Message edited by: BlackOnBlackATX ]</small>
