Intake Cleaning
tardboy21
Woodbridge, NJ
ok, so my SHO has 176k on it, and as far as I know has probably never had the intake cleaned. Haven't had a look at the runners, but in taking the end of the manifold off when changing the water pump a couple month back, even that part look pretty dirty.
My question is not as much on how to do it, as I will probably use some oven cleaner and carb cleaner, but what the gaskets will be like at this mileage?
Many say you can just reuse the gaskets as long as you are careful not to scratch.
Has anyone cleaned the intake on a high mileage SHO without replacing the gasksets?
93rev2sev
Hockeytown
The whole intake gasket kit is like $35...I don't see the advantage of even trying to clean it without taking it apart...and if you do that...use new gaskets.
Kens1992mtxSHO
The Commonwealth
Definitely use new gaskets. They're cheap and to clean it right you should take them apart.
Phoenix
SHOHOLIC
QC , Canada
You can re-use them. I also did that on my old beater and it worked without leaks BUT its a low cost insurance to buy some new ones.
shoclown
shoclown
sacramento ca
after you pull the intake jasco paint striupper followed by soap h20 work increadibly well, honestly it is a spray in wait a couple min and rinse all the carbon and build up will desolve, even in the egr
jonmon6691
No dough SHO
Wilsonville, Oregon
This is what yours will most likely look like:
main.php
Its going to feel like it was extrude honed and ported when you're finished ;D Plus, it will sound way better.
expy916
sacramento
Take the manifold off and spray a ton of carb cleaner inside and take the intake to a car wash and spray the **** out of it.
jonmon6691
No dough SHO
Wilsonville, Oregon
I've done this twice now on 2 different cars, so far the easiest way was a brillo pad(Fine steel wool) and de-greaser. I think if you had a pressure washer it would help a lot to get the majority of gunk out. I think a few people on this forum (Phoenix?) have capped the PCV tube and just have it released straight into the atmosphere, that will keep that gunk from building up again.
