black935spdSHO
hi i am new to this site and i have just recently purchased a 93 black on black 5sd sho. the problem is that the cluster lights dont work all the gauges work and the idiot lights work but not the gauge lights dont. i read on here that the dimmer switchs go bad but i picked up two from the junkyard and niether of them seemed to fix the problem i looked at the fuse block under the drivers side of the dash and all seem to be fine. is there another fuse block some where that i cant find or is there another common problem with these. is there a relay or a module that goes bad? also tried to remove the cluster but cant seperate the lower cable from the upper. if anyone knows a way to fix this please let me know thank you.
ken
ken
