Installing white gauges
MorpheusGPR
Ford TRIO
Indianapolis, IN
How much of a PITA is it to get a set of the white gauge faces off ebay and install them?
I have seen them for under $15 bucks on ebay.
They look white and then glo blue at night....thanks.
DVJ38
Hartford, CT and Worc, MA
Well if you have never taken apart your dash, a few hours. It's not that hard, you just need to figure out how to take the thing off and unplug everything and take apart the gauges. You need a set of star screw drivers, I didn't know that and it held me up. It's pretty easy to wire up.
There are some wires from the gauges that go to the control box of the gauges...I cut into the white thing that holds the gauge faces so that I could put the wires behind/to the side of it because otherwise the gauges wouldn't be flush. I used a drill and connected a bunch of holes, wish I had the dremel then.
A pretty easy instal if you don't know much about anything. Even if you don't though, don't worry about asking questions. :thumb:
Venom SHO s7
Washington
bizzy actually has a write up on it, and yeah its not as hard as you may think. do a quick search for that thread and i bet youll find it.
