Inner tie rod
Petersho1
IL
The ford's part # MES3344 does't fit. The thread is inside, should be outside. Does someone had similar problem? Where can I get the right one? What is the right part#? :madflame:
97V8SHO
V8's Own ALL!
Oklahoma
Dunno the part # but I replaced mine about a month ago with MOOG. I got them at O'Rielleys.
Mr. SHO
Philadelphia
I'm with stupid. I got Moog inners and outers for both sides from RockAuto. They fit perfectly, and the outers are much better than stock, IMO (greasable!)
Mr. SHO
Philadelphia
Haha... just kiddin' man. It's funnier when a little smiley guy is holding the sign. :D
tbeaucage
99SHOV8
Maine
For my 99 SHO, ford Part number MES-3344 has a female threaded end which attaches to the Rack. My SHO has male threads. I changed out the Inner Tie rod two years ago and had the same problem, but neglected to write down the part number. Bad road conditions has taken its toll on that Tie rod, and I now need to replace it again. Does anybody else know of the correct part number for this odd ball? I'm assuming Ford only produced a few of these with this configuration, since everywhere I check, the wrong part is listed.
Petersho1
IL
Get Moog. The part # is right for them, will fit. (RockAuto.com)
tbeaucage
99SHOV8
Maine
Thanks. My local parts store uses MOOG as a distributor. That part EV328 from that store was a FEMALE end. I'm not sure what the mess up with this part is. Anyway, I got the part from FORD. THey had an alternate part number ($97.00 mind you) which was the correct part. Only problem was, it comes as a 'Kit'.... containing 2 tie rods. Not really a problem, now I have a spare.
