in need of some advice!!
SHOPWR
beresford SD
ok i have had this check engine light problem ever since my SHO had 86k on it, i have pulled codes and have fixed the problems and have cleared the codes! and its still on i now have noticed that my car starts to hessitate under light throttle and once i let off the gas pedal the light will come on imedeatly. then in the morning when i start it i will let my car idle down then the check engine light comes on no matter what. according to the computer i have low EGR flow, low voltage canistar purge, secondary fuel pump voltage low,and BAD H20's which are only 1 1/2 years old... CAN SOMEBODY PLEASE HELP ME. thanks in adance!
mike
justin mccluske
washington
your o2s and egr are probly at falt clean your egr passages and find the bad o2 and that should fix your problems
SHOgirl1212
Not a stripper
Alsip
My light comes on a lot as well. I was told its the O2 sensor. I noticed that ONLY when the light's on, my RPM's go up and up as I accelerate, and then the car just "oomphs" into 2nd gear after hitting about 6000. It turned out being my idle control sensor, then my mass air flow sensor. I would suggest checking those out, because mine was solved after replacing them... but only temporarily. I don't know what else to suggest but that.
