matasho
bigshotsho93
ok so i have a sho that at first wouldnt stay running but now it wont start so i need some troubleshooting help. it started on mon. morn. i drove about 3 minutes and the car died, it took a long time to start back up then drove about 40 seconds died again same thing then drove about 20 sec. died then it would crank for awhile and start up run good for about 20 sec. and die, it idi this about 10 times and then i just towed it to my shop and now it would crank for a long time and finally start up but the same thing just die and as i was donig this it seemed to be starting up farther and farther apart then i got an insanely loud backfire out the exaust but a frw seconds later the car started and died again. and now the starter is burned out from all the cranking so i swapped out for a spare and now it just cranks not even trying to start and cranking alot faster almost too fast. so i check for spark-good check for fuel-fuel pump hums and stops like it should and the pressure guage reads normal so fuel is good. swapped out dis for a spare nothing swapped out maf for a spare nothing, so im tinnking cam sensor or the dreaded crank sensor! so i hope this is enough info to some good ideas from you guys. any more needed just ask. thanks for the help.
oh yea the car is a 93 mtx 3.2 swap and i had a super chip in but was kinda loose so when i hit a big bump the car would die pretty much like it did on mon. morn. so i took the chip out thinking that might be it, but didnt change anything and i also just recharged my k&n filter thats why i swapped out the maf for a spare too. man i need this car running so any info would be great thanks guys
