im freakin out
MeSHOYouHow
Indiana
Last night i had a brain fart and slid off the road at a T goin like 40. ehhhh. It bottomed out pretty hard. well my car is now spewing oil out the bottom. and my dip stick is bent! It is comming out of the left side of the engine, almost like it is comign out of the dip stick tube... not sure right now havent had a lot of time to look at it. But if anyone has any ideas what it might be, i would be greatful for any help.
SHOtimer
#2910
Santa Clarita, Ca
Well, you had to hit that pretty hard in order to bend the dipstick, because the dip stick is inside the oil pan. If the damage is that bad it probably won't be very hard to find the leak. You probably damaged the oil pan to the point where it needs to be replaced.
Doug
MeSHOYouHow
Indiana
the oil pan, and the tranny pan it turns out, the tranny pan has about a 1 inch indentation in it with a small hole
MeSHOYouHow
Indiana
I got a better look at it today. The oil pan is shatterd. Can someone help me out with good directions on how to remove the oil pan for a 93 ATX 3.2?
Denny
Taurus Homeland
Atlanta, GA
Yup, check out Kurt Metros' site, has instructions on connecting rod bearing replacement, which now that you're down there, this would be a good time to invest $60 in a set, an extra hour and do yours...trust me
http://www.kurtmetros.com/bearings.html
Also I PMed you, I have both
MeSHOYouHow
Indiana
do you have a tranny pan too?
And would you know where i can get a dip stick and pick up tube for the oil pan?
Ill take your oil pan! Let me know how much you want for it!
