Silver Bullet
Ok... I had a rough running issue recently with my 93' 3.2L ATX that was solved by throwing on a new set of Motorcraft spark plug wires + Plugs. It ran awesome for a week, and then a few days ago it started doing the rough running/misfiring again but worse. It starts up perfectly cold, idles fine & steady right where the tach should be, and even runs perfect for about 3-4 minutes until the engine warms up. Then it starts bogging down every time I try and downshift "Almost always a little over 2000RPM and above." Under 2000RPM it sounds and runs normal as long as I don't depress the pedal to downshift and accelerate. It also makes a popping sound during take off & downshift once in a while from under the hood like it's misfiring, and the tranny jumps around trying to determine which gear it should hit. At first I suspected maybe the new plugs were faulty, and brought the car back to the shop that installed them. The owner told me that it was oil in the plug wells that was affecting my spark, therefore causing the rough running/misfire. He said I needed a new valve gasket set installed. I drove it home and then back and forth to work for two days, and then decided to see just how bad the oil was leaking... To my amazement the wells were 100% DRY!
I ran my codes and got (157) + (158)... MAF circuit too LOW & also too HIGH.
Can my MAF malfunctioning cause my car to have the problems described?
