boat
Likes blue ones
Yep, I think I have this replacement in my future.
I can pull the key out while it is running. From searching I found this is a common symptom that it is either broke, or on its way to being broke.
I had read through Bizzy's dash removal Sticky, it talks about to remove the ignition key cylinder, one has to use a small allen wrench and push up through a hole in the plastic steering column trim, on a the "pin" that holds the cylinder in.
Am I missing something? When I was dis-assembling an interior a while back, I tried this and nothing happened. Meaning, nothing "pushed" in, and the lock cylinder stayed where it was.
So, how does this lock cylinder come out? By the way, it is on a 94 MTX.
Thanks,:wave:
Thanks,:wave:
