green94mtx
Anyone ever use an ignition cut rev limiter or a 2-step rev limiter on a V6 SHO?
<----megasquirt and yes I have my rev limiters set up for spark cut where first stage is a timing cut then the second is spark cut where it pulls spark out every some many revs then lastly set mine to pull all spark and fuel...
Semi spark cut sounds prettu neat on the SHO...
Where can i buy this? lolMegasquirt website... diyautotune.com ... megasquirt is not a plug and play for the SHO I built mine from scratch and my wiring is from scratch... I wired the megasquirt directly into a stock computer and I also removed my DIS and I am running fully sequential coil on plug via chrysler coil on plug...
My setup has been completely custom built that also take the stock vss and has launch setting and flat shifting ... soon will see boost and a ton of extras for boosting
