Ignition Code - 94 ATX
bump_26
Central Ohio
I was driving the other day and it just shut off without warning. (94 ATX)
It would turn over but would not start. After a few hours it started fine.
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
What should be done to fix this?
SeanMc
NoMoSHO
This is your crankshaft sensor. Check your waterpump to see if it's leaking, if not, it's just worn out. Have fun replacing it.
shoteen95
isn't a teen :D
Dearborn Heights, MI
Changing out this sensor is definately a weekend project if it's not something you've done a few times. And, if you're like me, it could turn into a week long project since I like to take my time, many breaks, and procrastinate like it's my job.
This is a very good step-by-step tutorial for a front 60k mile service of these motors. It covers things like water pump replacement, Cam and Crank sensor replacement, and timing belt replacement. A very good walk through with pictures that can help a lot if you decide to do any service by yourself.
http://www.shophoenixproject.com/lower60k/lower60k.htm
Check around the site some more, it also covers the upper 60k service (changing plugs, plug well seals, valve cover gaskets, valve shim adjustment), and has a parts list of what you'll need to perform the work yourself.
Best of luck and let us know how you go about getting it fixed.
DJ LYX
Bronx, NY
You could take a gander at Mark Nunally's video... its about the 60K service (CPS installation included)
However it has a couple of procedures missing for the ATX.
Still interesting tho
