Idler Pulley Bearing Number
Shogun71
Austin, TX
does anybody know the bearing number for the timing belt idler pulley on a 94 3.2?? i can replace the bearing alot easier and cheaper than i can replace the pulley. thanks.
Shogun71
Austin, TX
sorry. wrong forum. i don't have a v8. can a mod move this to the appropriate location?
s_p_a_c_e_ghost
indiana
does anybody know the bearing number for the timing belt idler pulley on a 93 3.2? i can replace the bearing alot easier and cheaper than i can replace the pulley. thanks.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
When Ford bought all the parts to these engines, they bought the rights to the sub-assemblies too.
So when you look thru the NSK bearing book for sealed double ball bearings with a 70mm OD and a 35mm ID, you'll find a list of bearings. As you look down the list, you'll find the listings skip over the correct bearings. This is because Ford still owns the rights to the bearings and they simply are not available.
That said, we do offer replacement pulleys.
Give us a call.
BTW, this is the V-8 section of the forum.
