identify this ground
greengiant
Holden MA
these grounds pictured here are pretty loose and the bolt holding them is stripped so i will be drilling and tapping it but, i dont know what it goes to to see whats working or isnt.
jmpSHO
Massachusetts
Not sure what it goes to but I would just sand down the contact and use a bigger screw.
Off Road SHO
Moderator
Probably headlight, turn and parking light ground. They used the frame as a way to save running long ground wires back to the negative post on the battery. I believe you'll find similar grounds on the driver's side of the core support.
Like the poster above (not the smart-alecky one, whose name will go un-mentioned but his initials are Chris Cantrell, the other guy) said, sand the connector and then use a bigger screw to mount it back in the same spot.
Tom
HotRodKid
mmmmm ... turbo
Western NY
drill out only the bracket
dont tap anything
run bigger self tapper into the whole gig
you cant tap sheetmetal, you can only jam course threaded screws into undersized holes
Vnuk1
Mr. Mayhem
Minnesota
Yeah mine was nasty so I buzzed it down to bare metal then repainted it, painted it black and it looks so much better than rust.
