I think I broke something
SHO24V6
Kansas
I was out at the track that week and I was getting wheel hop at the end of 1st gear and I noticed after words that I have a vibration now at higher rpms but only when the car it in gear.
please someone fill me in? shrug
Mr Anonymous
Tire Wall
SHO24V6:
Climb under the car and look around.
Might be a suspension part came loose, or you might have a bad CV joint/shaft.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
When I had a bad CV joint I was getting wheel hop as well. I didnt have vibration at high rpms though. Check by doing a very tight turn very slowly and if you hear a ticking from the side you are turning on, then you have a bad CV joint. If you plan on fixing them yourself plan on spending half a day to fix them.
jthomas68
Area 51
This has nothing to do with performance,please put future threads in the appropriate sections.
If you were getting wheel hop,you had a problem already.
