I need new struts
fz1nsho
Erie, Pa
Im going to replace all 4 struts. Where should i go? Im going to hold the stock stance but i want to get something worth while. 95 mtx. I'd like complete ready to bolt on without spending an arm and a leg. Let me know thanks guys
VortecGT
Wisconsin
Try rockauto.com and get some monroe quickstruts, also do a search on the fourm for the discount count to save some $$
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
There are a few options: SHO Source
I would suggest Monroes. I would replace the springs while you are there. Go for Moogs. You can go for the quick struts as well.
Springs only need replaced if they are sagging or rusted. Typically, the rears will be sagging badly by now, but not always.
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
I'd just go for the Monroe Quik Struts and get the springs with them. They may not be as still as the replacement Moog springs, but they are still stiffer than the stock springs and so should more than do the job for 90% of us out there.
marv
chicago
struts
I put the monroe quickstruts on the back of my 95 and i think it's to mushy, i would not get them again. I would get quickstruts for 92 or earlier and slap them on, i think they have higher spring rates.
I had quickstruts on the rear of my last white 94 atx, and I thought they were a big improvement over the stock ones. This is one of those questions that you get 10 different answers from 10 different people.
The quickstrut front springs are for the auto trans, so they will make the front of the mtx sit a little too high. Many people dislike that significantly.
.RaMpAgE.
Las Vegas, NV
intrax and konis.......i just put those on tonight :omgsho: other that sensatracs and moog springs or somethin or those kyb quick strut things those a **** of a deal
shobote
Naperville, IL
I've seen cars with quickstruts and would not go that route due to the rideheight. Better off getting the sensacraps, and buying springs/mounts seperately. Anything you buy will be better than old worn out OEM parts.
