I need help quick....SHO help...
bmcreider
Got Secondaries?
Fort Worth, TX
How do I get the caliper off lol?
I looked in the chilton's, and it's a POS....I can't find anything to unbolt or unscrew or whatever but I need to change out the front rotors and pads before I gotta be at work lol....so any quick help or guides or something would be nice....
bmcreider
Got Secondaries?
Fort Worth, TX
Better yet where are the caliper locating pins? I have the tool for it...but I can't find it lol...
yamahaSHO
E85 whore
Arkansas
There are two bolts that hold it on. Both are on the back side. One is on top, the other near the bottom of the bracket. Loosen those. I cannot recall the size or torque for tightening them. It's all in the Chilton's, just keep looking.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
There are 2 slider pins with rubber boots around them. Loosen them up and take them out...and then use a screw driver, or something, to pry the calpier away from the mounting bracket. Pads should drop out, and you can get the rotor off. You will them need a c-clamp or something to push the piston back in.
You need your tire off first... :D
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
It is a big Torx bit on the front calipers. Maybe a T40-T45... Not positive on that though.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Im older than you....not according to our "age"'s on the forum....but in life! haha
Thats how you talk to elders anyway....right? ;)
yamahaSHO said:
Hey, did you ever learn how to talk to your elders?! :D
yamahaSHO
E85 whore
Arkansas
Haha... Fokker! I've got you by a month :D
Sorry, I had to do it :D
Yamaha V6
SHO Enthusiast
Rhode Island
Note to those using this thread on other years; it's also a 12mm hex for the caliper to slider pin, and a 15mm hex IIRC, on the bracket to spindle up front on the later Gen 2's (which don't use a Torx).
bmcreider
Got Secondaries?
Fort Worth, TX
Ok I am an idiot I figured it out lol I was looking for it on the front, then found it on the back...thanks for the help though one thing I DIDN'T know was that I needed a C clamp to push the piston in, so now I gotta go get one of those :(
Yamaha V6
SHO Enthusiast
Rhode Island
Use a C-Clamp (or brake tool) for the fronts; DO NOT use a C-Clamp on the rears, or you will break the caliper. It's designed to turn in, not press in on the rears.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
This is true...as in, not false. Seriously.... :salute:
...oh and 30 days aint ******* yamahaSHO...I will take you out! haha
