i need help fast
kendal_jones
tha sho off
manchester ct
ok i just changed my clutch cable and now i cant get it into reverse without having it buck like iam letting off to fast i tryed to adjust the clutch pedal but i got no clicks i pulled up on it with my foot and also i cant get the cable to go threw the little hole on the transmission but its connected to the little arm can someone help me...
Mr Anonymous
Tire Wall
I'm willing to bet that changing the title of the thread to something more informative will yield quicker and more thorough responses...
Racer X
SHO Pilot, Retired
Connecticut
Kendal, first, wedge something underneath your clutch pedal so that it is as far up as it will go. A block of wood works well here. After you do this, disconnect the cable from the release fork, route it through the hole like it's supposed to go, and then reattach it to the release fork (the arm that the cable is connected to). Then adjust as necessary.
Hope that helps some. Good luck.
*edit*
For future reference, try to title your thread so that it would indicate what the problem you're experiencing is. This will help other board members with a similar problem when they go to search for an answer. :thumb:
