I need help....again!
dtp-sho
Tampa, FL
My car was doing fine until today. I went to turn on my car and it takes forever to turn on. When i go to crank it on it takes about 3 secs to turn on. It's like it's choking. Also some times at stoplights my car will make a jester of stalling. I have a 94 ATX. Need all the suggestions to what the problem is that i can get. Appreciate the help guys.
Ishodu
It could be starving for fuel or air. Did you try running your codes yet? If what are they? If not click the link in my Sig and let us know what you find.
dtp-sho
Tampa, FL
2 Things that i have realized that may help is sometimes if it takes to long... my radio and clock will reset, and sometimes when i turn it on the fuel gauge will drop near Empty( i just topped it off Friday and i haven't made any long trips or driven around too much).
MilTownSHO
Horicon, WI
Battery and connections good? Almost sounds as if somethings lose and losing memory...
dtp-sho
Tampa, FL
thanks for the reply....a couple people have told me to check the battery and the connectors.
