I Need a good guide for tranny fluid change
1993atx
udetectable sho
maryland
Hello everyone! I can't seem to find any online guides to walk me through a atx tranny oil change. Is there such a thing? Also-this may be a dumb question, but is there a difference b/t a fluid change and a flush?
SHO#7
Cincinnati
I recommend a flush. The easy way to do this is as follows. Find your external cooler ( in front of condensor ) remove in and out cooler line. Run in line into a bucket full of fluid. 4 gallons will work. Have another 5 gallon bucket to catch old fluid. Start car and make sure not to spill. You will run the 16 quarts through in about 5 minutes or so. That is a flush. If you want to do a service, drop the pan when done and change the filter. You will waste 5 quarts or so if you do that afterwards. But I do not like the dry pan start by doing a flush after the filter change.
I use Mercon V in everything. But everyone has their own ideas of what to use.
Bizzy
you can keep the car in park and start the car with the line pumping the fluid into a bucket. there would be no damage to running the car in park till the fluid stops spiting out. just make sure you shut it off as soon as the fluid stops flowing. By doing that you have pumped the pan dry, less mess when changing a filter. I've done this to a number of ATX cars I have worked on with no ill effects.
SHO#7
Cincinnati
I recommend against that. You will only get what is in the pan. 5-6 quarts. If you use my method you will replace 100% of the transmission fluid. My ATRA transmission shop that I run has been doing this for a while. However, I do agree that is you chose the other method you will not harm the transmission. But when the fluid is done pumping, you are running the pump dry ( with no **** ) and I recommend you shut down quickly. Good luck. :thumb:
1993atx
udetectable sho
maryland
So, let me run this by you the way i understand it. The "in" cooler line siphons up the new tranny fluid, while the "out" cooler line dumps the old. When the 4 gallon bucket of new fluid is accepted into the car, the flush is complete. If i choose to drop the pan and replace the filter, then i keep track of how much fluid i lose when doing this and add this after reinstalling the pan(4-5 qts). Thanks for the replies. :cool:
Here's the easiest and cleanest way to change the ALL the fluid and filter.
1. You may still spill some fluid when dropping the pan. Best just spread out the oil dry before starting.
2. Jack up the car and place on jack stands.
3. Next disconnect the line on the drivers side of the aux ATX cooler. Put the tranny side line in a five gallon bucket. Attach a piece of 3/8" hose to the cooler where you just disconnected the line and place it in the bucket.
4. Start the engine and wait until the fluid almost stops. There will be a definite difference in the amount flowing out.
5. Stop the engine.
6. Start loosening the bolts on the pan. There is still 3-4 quarts in the pan. Position a drain pan under the tranny pan and on the drivers side. Loosen and remove all the bolts but two on the passenger side. This will let the drivers side tip down as you then slowly loosen the remaining two. After the pan is mostly down and the fluid is in the drain pan remove the pan completely and replace the filter. Be sure to remove the rubber ring that will stick up in the tranny filter mount. Just bend it in with a screwdriver and pull it out with a needle nose. Do not scratch the aluminum tranny filter holding housing.
7. Re-using the OEM gasket and in a three pass sequence progressively tighten every other bolt until all are tightened. Do not over tighten as they really just need to be snug. Use a 1/4" ratchet drive socket.
8. Then add 10 quarts. Start the motor and wait until it almost stops pumping fluid out or until you see new fluid coming out. Better to waste a quart or two of new fluid to insure all the old stuff is out.
9. When the flow has almost stopped, shut off the engine and reconnect the hoses.
10. Add 5 quarts, idle motor and check level keeping it on the low side on the dipstick.
11. Then drive the car for a while to heat up the tranny fluid and recheck and top off the fluid.
The pan gasket is reusable if it is the OEM rubber one. Total system capacity is around 14-15 quarts. Buy a couple of extra quarts to get all the old stuff out.
1993atx
udetectable sho
maryland
Ah! That seems to be a good comprehensive procedure that even i can follow. Much appreciated! :thumb:
